2017 ar190
Lucky 13 cone
Ribbon delete
Ride steady
650lb ballast on the rear.
It worked at 1500 ft elevation at home but not at 3500 ft elevation at lake powell. I couldn't get to surf speed at higher elevation and had to remove weight from the ballast. I was then not able to go ropless at 190lbs, but my two kids could at less than 125lbs a piece....
3 videos: notice the wave size not the rider skill. First two videos speed is 10.8, last one speed is 10.3.
1st is without 650lb fatsac (I think I may have had my old 350lb sac on the rear)
2nd is with fatsac
3rd is with fatsac half full at Powell (I couldn't surf ropeless but I could foil) also I can surf the slingshot coaster at full ballast but not the hyperlite broadcast.
