a better anchor !!?!?
No. The proper way to set it would be to position the bow of the boat where you want the anchor then lower it into the water. Then I back the boat down to where I want the boat, and as long as I follow the scope/rode rule, (5:1, 7:1, 10:1) weather and bottom type dependent, I tie it off and it’s good to go. When I’m ready to retrieve the anchor I slow drive forward as I bring in slack, once right over the anchor I’ll tie it off to a cleat and drive it forward a little more and it pops out easy peasy and then I can retrieve it and stow in a locker. I’ve never had to exert energy to pull an anchor. To this day I have never had to re-set because it’s come loose or anything.
Of course you could heave/throw it over the bow, but where I boat you’d never get it far enough to follow the rode/scope rule.
hope this helps.
Fortress/Danforth/Fluke anchors are all extremely similar and will hold in different types of bottoms. As a few have mentioned above if you use the right amount of rode virtually every style will bite and hold.
It’s also important to note you need to have your bow pointed to the wind/current. If you set the anchor on the wrong side it won’t hold initially. But if you have enough rode/scope once the boat drifts far enough over it will self set.
Use this thing Right Here and you will read about anchors and each respective opinion for DAYS...
This may be a dumb question but how does this style anchor work if it lands on the wrong side and the flukes are pointing up instead of down?
@WiskyDan They won't... They're hinged to set down with gravity. They're not in a fixed position.
@mkbcaptain I'm all for more info, but this is one topic that gets:
