JetBoatPenguin
- Lake James, NC
Just installed my backup yesterday as well direct to the battery via a fuse..used industrial strength Velcro so I can try moving it around if needed. Used Blowsion thru-hull fittings. One tip: get the hole cutter that is one solid unit for the bit versus one that screws off. Most are made to screw off when in reverse...which means you may have to stop a couple of times if you don't to retighten the hole bit as you typically drill in reverse. The hull was surprisingly thin when drilling...
I made the backup with float turn on when the main bilge pump was up to the red.
Both working together moves quite a bit of water out quickly.
