212s
- 1000 Islands
- 212S
Looks the battery to switch wire is about 4awg. If you're going to run the power to the amps through the House switch which is probably rated 140a so you can turn them off, 4awg is plenty for one amp. If you intend to add another amp later on, you may need to upgrade or add to the wire gauge from the battery to the input of the switch to carry the additional current of the second amp. Don't forget you need to account for the current for the house system of about 35a plus the USB (?), so total will be 35+35+35+10=115a. 4awg in short runs is good for 100-150a depending on the wire so you may need to bump up to 2awg to ensure your capacity is safe. You have two options, replace the wire with 2awg to the switch, or add a second 4awg to the switch to double the current carrying capacity.I think I am going to push my batteries back some to make more room under this port seat for the new amp. Will have to change the power wiring from the batteries to the switches since I doubt it will be long enough. Anyone know what gauge wire runs from the battery to the switch?
Note that the amplifiers if wired correctly with the remote turn on from the stereo, will be in standby and draw very little power when off. No real need to run the amps through the House switch. Or you can opt to get another switch and run just the amps through it. This is important as the switches themselves have a max current capacity - typically 140a continuous, 200a peak.
Also don't forget fuses to protect the boat. The JL 280 amps have 35a fuses inline so you just need to fuse the USB (?) plug.
That would be fine if that's how you end up doing it.I'll run 4 AWG from the house switch to the new bus bar.
