tdonoughue
- The Woodlands, TX 77381
I would also recommend against boxing them in above. You will box in the heat (which is high for a can) and probably cause the fire you are trying to protect against... Besides, the firebreak afforded by the can (which is metal) blocking the hole is very likely greater than the firebreak provided by the drywall. So I think you are covered.
