- Raleigh, NC 27614
- 242X E-Series
@Glassman have you tried this? My immediate reaction is....well that will cover the part you can see....which is really only cosmetic. The key is the lower hull towards the centerline of the boat (the primary wetted surface areas). I bought my lift because of the loss of performance and cost of gas. All the growth on the bottom would take my boat from a top speed of ~50mph to a top speed of ~37mph. When you translate that throughout the speed ranges to RPMs, to ski at 28mph would take 9000rpm dirty, and 7800rpm clean. If you look up the GPH of those two RPMs from boattest, this was costing me a tangible dollars (just straight math alone says 15% increase in gas consumption, and I'm not sure GPH is a linear increase).
Back to the lift....we have gotten into a good routine now for launch and return.
LAUNCH-I go down and open the lift valves and start uncovering the boat (carry any big stuff to the slip with me). Family flows along with the smaller stuff. By the time I have the boat uncovered, bimini up, GPS attached, stuff loaded and put away on boat, bumpers off and lines removed the boat is down.
RETURN-Pulling into the slip is easy....no one needs to do anything to "help". Drive onto the airdock and cut the engines when I'm about 1/4 of the way on, then the boat slids to a halt most of the way on. Then get the boat ready to be put to bed - bow cover on first, GPS off, stuff off the boat, cockpit cover on, plug pulled). Then I walk to the front and position the boat properly on the lift (a little side to side adjustment is usually needed - just a pull with a rope) and turn on the blower. Finish snapping on the dock side of the cockpit cover, then 2-3 minutes later she's up and I adjust the levels as it get to fully raised. Shut off the front bag first, then slow down the starboard bag and then shut both starboard and port bags and shut off the blower. Front fills the fastest as it is the smallest. Starboard fills slightly faster than the port bag as the line to it is shorter.
Hopefully this helps understand the operation better.
