Amp Install - Nothing Happening
Were you able to get the remote wire to work? I am having the same problem. Remote wires hooked to the app but the app won’t power up.
The HTX-2 amp comes on fine if I run the remote wire to the + terminal of the battery, but I get noting from the blue remote wire off the Fusion head unit.
Is there a setting that enables the remote? Or, is there not enough output on the remote to turn on the amp?
The HTX-2 amp comes on fine if I run the remote wire to the + terminal of the battery, but I get noting from the blue remote wire off the Fusion head unit. Is there a setting that enables the remote? Or, is there not enough output on the remote to turn on the amp?
The remote turn-on is very low current as it just signals the amp to turn on. Check that you're getting 12v from the blue remote wire when the Fusion is powered up. If not, there's a bad connection somewhere.
