My point was that you could be getting ready to pull out..... you look around and everything appears clear.... then someone decides to swim past the back of the boat... spending on the height of your transom you might not see them as you look backwards.... if you backup and hit them, there isn't a prop in the water to do serious injury. Not saying they wouldn't get injured but a prop will cut or amputate, which can result in rapid blood loss.
Stuff can happen.... even with the safest captain.... all I'm saying is a jet eliminates that additional injury potential vs a prop when unexpected things happen. The guys earlier post about the boat hitting as stump and kicking the outboard into the back of the boat and the operator losing a hand is a prime example. A Yamaha Outboard Jet would have prevented that.
Eliminate? Not likely. I dare anyone with long hair or a child to swim under or near a jet intake while the engine is on. It’s ain’t gonna be pretty and would likely drowned. There are also plenty of attachments people add on jet boats (metal fins, surf attachments, ladders etc for example) that can cut someone if the boat was backing up like that and run over people. Jets seem to give people a false sense of security nothing bad can happen. They’re called accidents for a reason and a jet is maybe a little safer but probably not when you have a drunken idiot at the helm.
