- Lake Ray Roberts, Texas
- Boatless
- NA
- Other
- NA
So I'm reading that this is 2010 boats, would this affect my 2011 242?
Look at your oil cooler. If there is a little arrow stamped in the metal next to the 3rd bolt down (below the filter), then you should have no worries. Otherwise, it most likely affects you.
...... The one thing I will do before season starts is loosen and retorque the bolts to spec. You may want to so the same.
Got a courtesy call from my dealer today. Seems as though Yamaha has no record of me purchasing the extended warranty (dealer is getting that straight now since they have record that I did). However, even with them assuming that I had no YES warranty, Yamaha was still willing to replace one cooler (parts and labor) or both (and I cover labor). That may be good news for those of you that run out of warranty and have the issue if you havent had it already.
If you should do this, I would recommend installing new fasteners - the revised version - and use ARP Ultra Torque Assembly Lubricant.
Fasteners stretch and fatigue. This is a contributing factor in this issue as I understand it.
My boat is currently at dealer. I am still under warranty. Yamaha replaced bolt on one cooler. Yamaha is unwilling to do anything else with oil coolers, unless they are leaking or break more bolts.
Probably gonna fail during vacation boating trip or out on lake Michigan with my wife and three year old. Frustrating scenario.
side note:
took boat to dealer to replace broken reverse cable. Warranty will not cover. Yamaha says I hit something and broke cable. I said show me the dent.
I have heard the same although I am waiting for a PM back from someone on yjb that claims to have done a full engineering analysis. For those that do not want to replace the coolers, replacing this 3rd bolt may become regular maintenance that is done every season, like changing the spark plugs.
Hi Davel 501
Yes, I am working with Gary at Nielsens, and they are being professional and wonderful.
I would highly recommend this dealership to anyone looking to purchase or needing service.
I have spoke and dealt personally with their main technician in the past and he is very knowledgeable about the jet boats.
Absolutely no complaints regarding the dealership.
I completely understand that the dealer must get all warranty work authorized through someone at MOTHER YAMAHA.
Sometimes I think wining on here may help.
