- Lake Ray Roberts, Texas
- Boatless
- NA
- Other
- NA
I would be more concerned that you only have 100 hours on a 2011 boat! You better get on it this summer!Early 2011' also have the oil cooler issue. My 2011 has the old (same as 2010) oil coolers. I'm just lucky like that. I have 100 hours on the boat and no issues as of yet (knock on wood).
When I spoke to the dealer he told me the real issue was the way the robot torqued the bolts. I had debated doing this earlier but didn't, you could just take the bolt out and replace it with a new bolt and the correct torque. The issue is that when you do this you break the bolt anyway so be prepared in case. I am lucky mine just went and it was not during the summer and the dealer is treating me right (and no waiting). I thought it would not happen to me after so many years and many hours but it did last January during a nice warm winter day. You may want to see about fixing it now before the season starts.
This shit really pisses me off after hearing all the problems with this part. Yamaha should step up and recall this piece of shit oil cooler!
Where you fixing it your self ? I did mine and put a grade 8 bolt in it , I couldn't imagine that braking again
Wow I will def need to watch mine , that's crazy to think a grade 8 and 10 would brake !!!First time I used factory Yamaha bolts, 2nd time I used Grade 8 SSbolts, 3rd time I used special sourced grade 10 bolts. All 3 times the same bolt sheared. The upgraded cooler actually has a much thicker bolt in the 3rd hole down.
