Matt Phillips
- Lake Tahoe
- 242X E-Series
As others have said, there's more maintenance with an I/O due to their complexity: bellows, lower ends, transmissions, water pumps, etc.
Jet boats are simpler and here's what I found for pricing on annual maintenance today on Amazon:
Initial things you'll need that can be re-used year over year:
-- Vacuum oil extractor: $77.63
-- Small Oil Filter wrench: $14.11
-- Magnetic spark plug wrench with 6" extension: $15.44
-- 3/8" sliding T-handle for spark plug wrench: $8.99
-- 50-pack Puppy training pads (to catch oil where needed): $13.50
-- Teflon spray grease (to use on steering cables, reverse buckets, etc.) $10.13
-- Fogging Spray (some don't use this, I do): $3.67
-- Permatex Anti-seize for spark plug threads (some don't use this, I do): $3.89
-- Grease gun (you'll use this on either boat as it'll be needed for wheel bearings): $20.55
-- Royal Purple Grease (for wheel bearings and engine bearing...that's what I use): $12.47
Maintenance Total: $147.36
Total with Grease & Gun: $170.25
Annual Things I use:
-- Mobile 1 Synthetic: $46.88
-- K&N oil Filters: $20.50 (2 @ 10.25)
-- 8 NGK Iridium Plugs: $49.62
Annual Total: $117.00
As you can see, your first year will be less than $300 for maintenance and all of the tools to do it. Subsequent years will be less than $125. Several members on here have written instructions on how to do oil & plug changes with pictures, so it's pretty simple to do. Total time for me to do the annual maintenance is now about 2 hours of my time. I also enjoy it as I get a chance to look closely at the engines and inspect for anything that may be amiss.
