1BadTundra
- 212X
As an engineer, I'm curious why you're OVER sizing the radius instead of UNDER sizing it. Genuine question, not being a dick.Don't forget to do a radius compensation in your drawing, if not already done so. In other words, it is not wise to make your bracket's radius the EXACT same as the tower's. It probably won't fit correctly, depending on the tolerances of the printed or machined part. If that bracket is going directly on the tower with no gasket in between, I would oversize the radius by 0.005-0.010. If you are running a rubber gasket or such in between, the radius will definitely need to be compensated for as well. I.e. if you are running 0.062" thick rubber between the bracket and tower, the radius on the bracket should be at least 1.012. As a machinist, I have to constantly have the engineers fix their drawings because they can't understand this simple concept.
In theory you never get perfect line to line contact. I get that.
Over sizing makes a single line contact, under sizing gives two lines of contact. Assuming rigid (metal) components of sufficient strength.
I would much rather have two lines of contact as compared to one line of contact. If the materials are not of the same relative stiffness, then one will deform slightly. If you are undersized, then the "legs" will flex and give the theoretical line contact you want.
Thank you, this is awesome!!Xometry can print and ship you anything you want. They're reasonable and I've worked with them in the past. They'll even make you an aluminum one and anodize it black if you want. Cost a little more, but would look baller and last much longer than a 3D printed piece.
www.xometry.com
Here's what your part looks like:
I added 0.030 flats on the tips of your radius there. Will help with manufacturing, and you don't want those sharp edges anyway.
STEP file you'll need for quoting through Xometry is attached.
Either Black or blue@1BadTundra, what color are you wanting?
I appreciate that... Machine work and aluminum may be a bit expensive for just 2 filler pieces like these.OP, if you'd prefer aluminum and you are willing to wait 1-2 weeks, I have recently brought anodizing in house and am awaiting a new tank and dye for black anodizing (if that's the color you want). I currently have blues and grey on hand. If no color wanted, throw some solid dimensions at me, and I could send these brackets to you with a raw machined look much quicker. If interested, let me know and I'll work up a figure for you.
A sample of some anodized parts I just shipped to a custom boat builder:
Thanks, I didn't even think of that.For 3D printing, consider checking with your local public library or any community makers spaces. Our public library has a 3D printer for member use.
Yea, that's exactly what I'm looking for. I didn't know there was a place that had a 3D print database like this.Here's something in line with what you are looking for:
3D design Light Bar Frame | Tinkercad
Just a few minutes of tinkering.
