Slack
- Matthews, NC
- Limited S
I have to remove my tower before I can put it in my garage for the winter.
- Disconnect tower light connector. I actually moved my disconnect connector to the pivot point of the tower for easier disconnection.
- You need at lease 2 people, 3 would be ideal. One person on each side and one holding the top of the tower with the tower in the lowered position. All persons will need to support the weight of the tower at some point in the process.
- Remove aluminum block from each side that holds the limiting cable.
- Remove the E-clip from each side, punch out the pins in the pivot point.
- Once pin is removed, simply lift and remove. I had to give mine a good tug the first time.
I hope this helps. It’s not bad when you have 3 people.
