Congrats! What color combo? We have a 2017 as well, but its the SL w/ Tech, so not as many bells and whistles.
Here’s some feedback...
One you hitch/unhitch the boat from the Armada, you might hear a humming/ticking shortly after... It’s the air suspension in the rear leveling the load, and takes maybe 30-45 seconds to subside.
When backing up your trailer, EVERYTIME you go into reverse, unless you like being berated with audible tones, you have to disable the “sonar parking sensors audible alert”, via the soft button on the backup camera screen. Also, if you are not backing up relatively straight, say, out of your driveway, you will want to disable the “cross traffic” intervention (button is on the lower dash, left of the steering wheel) - otherwise the vehicle sees your trailer as cross traffic and will abruptly slam on the breaks. The annoyance here is that say you need to pull forward mid maneuver to straighten up, you have to remember to disengage both settings again when backing up. I question why the engineers didn’t disable, or provide an option to disable the rear sonar when engaging “TOW” mode. I typically don’t find the need to engage tow mode in relatively flat Florida. Also, if you haven’t checked, the Armada comes with a 7 pin wiring harness, so you might need an adapter for your trailer (our trailer is 5 pin).
IMO, it does a great job towing the boat, but is thirsty (9-12 MPG is what I see when towing at highway speeds). Not complaining - just sharing.
Non-towing related items...
Some individuals on the Armada forums have commented about the gas gauge not being very accurate once under 1/4 a tank - you’ll have to see what your experience is. I’ve had times where it appeared we had about 1/8 a tank left, but would only take 16 gallons of gas at fill up time (its a 26 gallon tank). I think the most I have ever pumped is ~21 gallons and that was after the fuel light came on. I find I rely more on the onboard computer’s distant to empty than the fuel gauge once we’re below a 1/4 tank.
The OEM Bridgestone’s aren’t very good in light snow (we found out last year during a trip to the mountains of NC), but it seems like you are in AL, and that shouldn’t be much of an issue for you. Just replaced ours with some Michelins.
Let me know if you have any questions!
