As luck would have it and as i use my Boat quite a lot i usually give it a good once over about every month to 6 weeks, I was returning home about 3 days ago and a gust of wind broke my Bimini deck loop so i did the quick repair and tied the strap around the Wake tower and carried on home, After replacing both deck loops it got me thinking about how i can mod this and here's what i came up with, Total cost about 5 dollars and a lot stronger and never to break again.
View attachment 20725 View attachment 20726
Here's the offending part
View attachment 20727 View attachment 20728
Parts required, 2 x new stainless bolts and spring washers and 2 x 6 mil stainless Eye Nuts
A little stainless welding
Completed item.
Remove that old mild steel Alan screw from the Wake tower and replace it
Replace it with a new stainless Bolt that does 2 jobs, A lot stronger and also no long straps to worry about just take up the slack and loop it at the top through itself and it's really strong and shorter and you can always revert back to the old way if you want to.
I replaced the eye deck loop for a new stainless one
I'm well pleased with that and being shorter it's a lot stronger and no flapping or having to move it slightly when opening the walk through door, let me know what you think, Total cost around 5 dollars.
