2kwik4u
- Buffalo, NY
Are you at altitude? Any signs of cavitation? What kind of load at that speed/rpm?I just purchased a 2018 AR190 and it runs at a max RPM OF 7600 (is that the stock limit) at 36/38 mph. If that's max RPM then a repitch could be on it's way, any suggestions?
A tune can get you more revs. A reseal on the pump or L13 cone can get you more pump loading and less cavitation. A repitch might be in order if you're above 1k ft elevation.
