AR192 Budget Stereo 2x 12" Subs!
I_squared_r
Medellín, Colombia
242 Limited S E-Series
I picked up this 2014 AR192 a few months ago and have been doing a little work to it before Spring comes. I always like big audio for cheap because I don't see the value in $2000 systems. I'm sure they sound great, but isn't my preference. So here's my stupid, simple, and cheap build. Here's what I bought:
MTX Terminator TNE212D 1,200W Dual 12in Sub Enclosure $129.95
4x Kenwood 6.5" 2-way Marine Speakers $83.42 (Amazon Warehouse Deals)
BOSS Audio KIT2 8 Gauge Amp Install Kit $14.99
Rockville RXH-F5 1600w RMS 5-Channel Amp $149.95
Paid with my Amazon Card 5% Rewards $18.92 in account credit
Total Cost $359.39
The amplifier is inside the helm underneath the stereo. I used some thin plywood that I had laying around, drilled holes for the existing studs, and then screwed the amp into the plywood. Really clean install. It's a car amp so I wish that I had taken it apart and coated everything with conformal coating spray. Maybe I will do it later.
The speakers in the bow were in terrible condition. It crumbled into pieces when I went to remove them.
The subs fit through the opening with not a millimeter to spare.
I had some aluminum stock that I bent 2 90 degree angles in and used the existing stud to the right. Still some room in front to fit a small cooler or other.
Video below. Stereo's volume is at 50% and the vibrations are from the seat. I will be adding foam strip between the seat's hard plastic and the boat's hull. Sorry if you don't like Spanish music :p Maybe I will add some vent on the side of the compartment for sound to escape. The clarity after removing the seat is crazy good.
<iframe width="560" height="315" src="
" frameborder="0" allow="accelerometer; autoplay; encrypted-media; gyroscope; picture-in-picture" allowfullscreen></iframe>
Must be salt? This pic goes to show those "marine" ratings for Polk DB651s are rather misleading...
Total Cost $359.39
What is your crossover set to on your amp? When you lifted the seat i could hear words coming out of your 12's. Should just hear bass and nothing else. Might just be the video.
Right! It looks like condensation sits in the bow area because only the front speakers rotted. The new kenwoods are all plastic with the exception of the magnet.
Good observation. I didn't spend any time to tune the system and I wasn't aware of this issue. But it makes a lot of sense now that I think of it. Thanks.
If you change if over to low pass and adjust the HZ down to about 50-75 depending on your subs and turn the gain up on your amp to about 2/3 maybe 3/4 it should jam.
Will do. Thanks. Now I need to check the subs in my car.
I have one of my subs under the seat and added a vent, night and day diff....especially once you tune it and the sub breaks in fully.
I have an extra vent, made of starboard if your looking for one PM me....I bought 2 of them but my other sub is in the large port storage and the vent isnt quite large enough, so I'm gonna have a shop make me a custom vent that matches the other one but prob in white, if so dont need the extra one and will be listing it on the classifieds here.
No pressure, but venting that sub will make it come alive.
I was thinking to do something like this. Give me some time to mentally prepare making that large cut haha.
Totally understand, but you've come this far to get great sound...
Im in the same situation, my 2nd 12 doesn't have a vent so I keep the door open, but when I'm underway I lock the door which totally kills my vibe, so I need a larger vent than this one to fit
The diff is night and day as you can see when you lift that seat.
I need to feel all my bass, hence trying to do the same things as you.
Once I get the white one I'm going to order to install on the port storage areas, I will post some pics, expect to get my next round of mods started in late Mar.
12 inch subs move a lot of air. Letting them direct vent into the cabin will make a big difference. Even if the amp is mounted in the battery comparment I would recommend rethinking that 8 awg wire and upgrade to 4 awg ofc or 4 awg tinned ofc. Make sure to have a portable jump pack on hand as that amp is hungry.
That is a lot of bang for the buck, enjoy.
I was wondering what if ur sub encloser is in the large center compartment would it sound better to vent that too? If so where would i vent it, on the door?
That's the plan, I am going to get a custom vent made and enlarge the existing vent so I can keep the door closed but all the bass can escape.
I am venting it on the door towards the bottom, there is an existing vent there but not sufficient for what I need, so will cut that out and open it up and then cover it with the new vent.
sounds great please post some pics for us.
