Is it possible to add a flush table mount on the lower part of the rear deck like the larger boats have. Looking for input from anyone whos done this or something similar
I ordered the table kit from partzilla part number SBT-TABLE-KT-17 but it took a little longer than a month to arrive. You can save a little money and order a table kit from garelick and probably will arrive faster garelick part number 75359. But the Yamaha table is a lot nicer. It will come with a spacer bracket but you dont need it for the swim platform. You only need it if you put inside the cockpit area and it will still need washers to level the table.
I usually put it in the water in northport. As far as the table I was thinking of doing a recessed mount into the center of the lower tier floor on the back that can then be used for either a table or bbq
Probably you could, but the method I listed is already proven. I put a grill or table on mine. I bought 2 brackets, 2 poles, and a yamaha table. So I have the table in the cockpit and the grill out back. I could put the table out back, but I never do.
So do you have a spacer there on the cockpit table mount? Any pics of how it's mounted in the storage area.
Also did you use a spacer to make it level on the swim platform. Ordered a garelick table last year and just now getting around to install. Want to be able to put a grill on the swim deck.
No pics and the boat is still in storage. I bought a 6"x6" or 8"x8", 1/8" thick aluminum plates for the backing plates. The cockpit area needed a spacer and the 1 with the yamaha table kit isn't a good angle. I added a few washers underneath to level it.
No. Only thing to say, is to chose a good side when tying with other boats. I had 1 drunk guy put his palm flat on top of my grill. He seemed ok though
Yikes. Thanks for info. I installed it last night. I am a little worried about the flex in the fiberglass there. And the table is on an angle. Maybe that'll be better when its in the water. I put an aluminum backer plate on there. Do you notice any flex?
You put it a little more to the center than mine. Yours is better when tying boats because the grill would be out of the way of people passing through.
Theres a little flex but i'm not worried about it. No gelcoat cracks after 1 season of grilling.
I have the stainless steel arm and its perfectly level. Maybe the angles are different between aluminum vs stainless part.
Thank you, I figured the angles are a little different. Might try to get another leg and see how the angle is. Mounting the interior one is going to be a PITA trying to figure out the right spacer for the mount.
