I can't tell if you are being completley serious here...
100% Serious. No sarcasm, shenanigans, or ballywho intended
Let me ask you this:
How would an average owner know when are those bolts starting to get cross-threaded/out of specs - vs working fine?
There is an obvious difference in feel to a cross threaded bolt as compared to a normally threaded bolt. Running torque could be measured as well. The hand knob should not be used to "pull down" the tower, but only to tighten against the tower once in the fully "up" position. There are enough threads engaged in my experience (limited to two boats) that you can tell if it is a "free running" thread, or if the thread is damaged. Measuring running torque, visual inspection for damage, and "feel" are the only way to measure this.
There is zero information in the manuals (owner or shop) regarding torque values, tolerances, any specs...
Correct, and this is a problem
What exactly would you measure to determine your tower locking bolts/mechanism is safe and not going to wiggle out on you?
IMO if the threads are free running until tight against the tower, then a proper torque should be specified. I use "damn hand tight" for my torque setting, however including a hex head and tool from the factory would go a long way in clarifying how these are supposed to operate and be safe. A well torqued and loaded bolt will inherent not "wiggle out" under use. Damaged threads, under torquing, or improper seating will all aid in that bolt backing out, as you've experienced first hand.
While I don't doubt you "have the education/experience to perform the structural analysis on my own", keep in mind you are not necessarily the only operator of that tower. By the time you purchased your new boat that tower might had been lowered and raised a dozen times. So, even if you had never taken it back to the dealer, do your own service etc., the damage could had already been done. No?
You are exactly correct. Currently I am the only operator of my tower at this point. The dealer I use has high bay doors and doesn't have to lower the tower when it's there. I was fortunate in that it was not damaged before I received the unit, and has not been damaged since. I think others (including yourself) have not had this good fortune.
Not trying to be facetious but you are making claims that are a little confusing, to me:
So, is it good design? Or not so good design?
My point in the post was not to say its a good design or bad, merely that in an as designed state it doesn't have structural deficiencies. To say that all AR forward swept towers are faulty is incorrect. To say they are all without fault is also incorrect. All designs have compromises, weaknesses, and strengths. This particular design has a lot relying on the end users getting the interface correct, which is an issue.
My aim here is to provide education with which other users can draw their own conclusions. We each have to judge the risk that we subject ourselves, and those that rely on us to. In my opinion, this tower design is acceptable. In my experience frequent checks for damage, and careful use (procedural safety, not inherent safety) is keeping my risk low.
Considering those bolts have now been reported to pull/wiggle out in at least a dozen cases, what are the options?
How does one know that thread is getting out of wack?
Visual inspection of threads, feel of the running torque during insertion/threading.
The OEM bolts can be replaced but can't buy the base (with female thread), it is one part with the tower...
The base would have to be replaced by a machine shop should those threads be damaged. I intend to remove my tower this winter to run some wires. There is a snap ring that will remove the base from the tower I think. I'll be certain to document that process. The fact that Yamaha doesn't sell that piece as a repalcement part is a mystery to me, as the premise of damaging those threads had to have crossed someones mind at some point.
Not trying to be argumentative, but I think this is a serious problem, it's probably good letting others know and beware.
(I wish I had known about this issue!)
I understand. You have also had a VERY severe interaction with this particular issue. I think you've done an exceptional job of not lashing out publicly at Yamaha over it. My over arching goal here is to provide some insight for others to read/understand on the issue at hand. Provide some information, and possibly some insight so that others are aware of the root problem, causes, and preventative measures.
As AR owners, we're all in this together. Education is key in sound decision making. I don't want to see any more harm come from this design issue. I also don't want to scare away existing or potential new owners by making a problem worse than it is. New owners should inspect these bolts before delivery, and existing owners should check them on a regular basis both for damage and tightness
