Audio upgrade questions
Quality looks very good. I have seen a little better connectors in very expensive RCA cables years ago but these are more than sufficient and well made. The wire itself is shielded and looks great.
Also, that’s their mid grade cable. They have better, I just didn’t feel the need to upgrade any higher than these. I used their mid grade power and ground wire and it was very nice so I knew it would be more than sufficient.
Perfect. I’ll check out the power cables as well. How many feet of speaker cable did you use ? I’m thinking 150ft should be suffice ?
I ordered 100’ at first and used a little too much in some spots but I ran out and couldn’t do either of the bow speakers. Also note that I cut two speakers in on the swim platform and have no tower. I still think you’ll probably need around 125’ though so I would order 150’ to be safe. It sucks to run out mid job and have to wait, especially in the mid summer heat.
What in-line fuse holder did you use ? What amp fuse ?
I used a 100A in-line fuse with switch I bought on eBay or Amazon.
