This is the one I'm using.As others have described, it depends. What charger are you using?
Careful with any charger which is not sealed and marine rated - batteries can gas hydrogen when charging which is very flammable and unless your charger is "ignition protected" you need to keep it well away from the batteries or you risk igniting gasses and causing a dramatic fire and/or explosion.This is the one I'm using.
Not sure which one to use I have 2 of them.Since that appears to be an automatic charger (where it automatically changes current based on draw from the battery), I would leave it hooked up all the time as long as everything was well ventilated,
@jsg73 .....EXACTLY the point. EVERY aspect of a charging discussion depends on the battery chemistry: (Flooded, Gel, AGM, AGM/TPPL) AND the battery charger: (old style 12v 2-12 amp with a trickle charge profile that will boil or sulfate your batteries OR new style with up to 6 dedicated and regulated cycles that are governed by constant battery feed-back) some batteries gas-out others have internal valves and don't gas out. Depends, depends, depends.As others have described, it depends. What charger are you using?
Out of the 2 I pictured above which would be better?
So I assume use the blue one then the grey one?@jsg73 .....EXACTLY the point. EVERY aspect of a charging discussion depends on the battery chemistry: (Flooded, Gel, AGM, AGM/TPPL) AND the battery charger: (old style 12v 2-12 amp with a trickle charge profile that will boil or sulfate your batteries OR new style with up to 6 dedicated and regulated cycles that are governed by constant battery feed-back) some batteries gas-out others have internal valves and don't gas out. Depends, depends, depends.......FWIW my choice: (minimum) AGM with smart multi-cycle charger .....(best) TPPL with a smart multi-cycle charger.
This is getting silly because I feel your getting to technical on me here, here's the pic of the boat battery and the chargers I want to do is maintain my battery until I go back out, not looking to spend $300.00 or more on a boat battery charger..Ok, this thread has just gotten silly. Almost every response is telling you what each of your chargers is meant to do. Without you telling us what you are trying to do, and what kind of batteries you have, you will just have to read the recommendations and make a decision.
Unless you care to share that information, all we can do is tell you what your charger choices can do.
1. Do you want to charge overnight or over the week for the next weekend?
2. Do you want to maintain your battery in the off season?
3. How many batteries do you have and what size/type/composition are they?
4. How often do you plan on depleting these batteries and wanting to recharge?
That will tell you which one to use. Either way, they will both charge your batteries. But as stated above, if you have newer AGM or other higher end batteries, you may be in the market for a better charger with cycles. And if you have two on board that will need charging on a regular basis, a multi-bank onboard charger may be the best option.
