Beachbummer
- Houston TX
- SX
Humble suggestions for troubleshooting...
1)Turn battery switch to off, and insert multi-meter prongs where the fuse goes... Check Ohm measurement....Should be open/pretty high.... Then go crazy jigging wiring near and around trying to replicate the possible short. When the Ohms reduce greatly, go to zero, BAM, there's your short.
2)If you want to diagnose without the rectifier you can disconnect it and run the engine briefly (similar to car with no alternator...not a long term fix, but 10 minutes with a well charged battery should be no problem whatsoever), Engine will be draining battery and not charging, but it will take the "rectifier current" off the equation, if everything else fails and it doesn't blow the fuse with the rectifier disconnected, there's a good chance it's to blame.
If it was me, to troubleshoot, I might rig a 12v 30 amp breaker with 2 leads and use it in place of your breaker so you can reset with push button vs replacing fuses while you figure this out.
(Something like this https://www.amazon.com/dp/B000GGONYM/ and rig 2 wires/leads and insert on each side where the fuse goes now, to make you a "resettable" fuse)
These are a bit wild but not overly so. Try at your own risk, you mileage may vary
EDIT: changed "voltmeter prongs" to "multi-meter prongs" to make it more accurate.
