212s
- 1000 Islands
- 212S
Thanks for the edit...I was scratching my head until you said this. Yes the ACR will disconnect once it senses that charging current is no longer available. My stock switches and ACR does the same thing - after turning off the engines, the ACR light will stay on for about 20+ seconds before it breaks the dual battery connection and goes back to start and house isolation.Edited to add: checked out the Blue Sea website. Their diag chart shows that in order to disconnect both sides of the ACR must be below 12.75V for 30 seconds. So maybe it is operating as designed?
Typical fully charged batteries sit around 12.7v idle. Let it sit for a few minutes and it should settle down to that level, leave the charger off then turn on your amp with the volume set to zero and see if the voltage drops significantly, like 0.5v or more. If so, you have a bad amp that is bleeding current. If the voltage drop is subtle, like 0.0-0.1v then that's fine and it could be the ACR is bad.
