- Raleigh, NC 27614
- 242X E-Series
@ScottyOK I am thinking that this post by Julian explains how your configuration works. Hopefully it is the same in my boat and will work the same way. So just leave it in the on position and when you are stopped at anchor the draw is only from the house battery, leaving the starting battery alone. Seems reasonable and hopefully this is how it works. Would you be safe anchored up for 4 or 5 hours listening to music? So then my only question then is.... When do you use the "Combine" setting? Would it be a backup in case the starting battery has gone bad? Any thoughts? @Julian ??
Yes, the combine setting is used for when one or the other batteries is low and you need to combine both banks to one battery....typically if the starter battery has run down for some reason and you need the house battery charge to start the engine(s).
