Hector Leiva
- FSH Deluxe
Purchased and would like to install a two battery battery tender (Deltran Battery Tender 022-0165-DL-WH). However, not certain how to connect so that both batteries can be charged simultaneously or in a first and second order. Boat is a 2017 190 FSH Deluxe with one battery each installed by manufacturer on the port and starboard compartments closest to the stern. Battery switches are located in the port compartment and it appears that primary battery cabling is also on the port compartment. Starboard battery appears to be wired as a secondary/slave. Any input info would be greatly appreciated.
