battle with surge brakes trailer winning
gthh
Buffalo, NY
Hi guys need some advice
working on replacing my surge brakes actuator/resovoir and I was not getting any brake fluid to the brakes stroking the surge brake piston. Took off the surge brake and pump the piston and only pressurized air is being pumped out. The resovoir is full. Any ideas. thanks
George
Sounds like it is sucking air. Are you sealing the outlet when releasing the piston? Some guys will run a piece of hose from the exit back into reservoir itself so you are not sucking air.
Making progress. I managed to get brake fluid out of the solenoid valve by pumping the master cylinder piston several times while it was apart. Seems like I needed longer strokes than the screwdriver could deliver. What a nightmare. should be good from here. Thanks
Place a sturdy board such as a 2 x 4 into the safety chain loop below the coupler. The board should be four feet long or more so it will extend well above the actuator. Position the board to press against the front end of the actuator’s coupler and use it to force the coupler case into the actuators outer housing. This pumps the brake fluid into the trailer braking system. Manually pull the coupler case back to fully extended position and repeat the process.
Thanks Red, this method is a lot easier than using a screw driver to pump the brake fluid.
Find someone with a vacuum bleeder. I did mine a week ago and the vacuum bleeder makes it downright easy. I have a mightyvac 7400 with the brake bleeder addon. It serves a lot of purposes other than just bleeding brakes. Great tool to have around.
