FSH 210 Sport
- Tranquility Base
- FSH Sport
Update:
First tow yesterday, about 20 mins to the second closest lake to me.. 50-55 mph.
I pulled out my heat gun and found that the non brake hubs were 76* drivers side and 80* passenger side. The brake hubs were 118* drivers side and 150* passenger side. I checked them again when I got home and the temps were the same. I checked them with my fingers and the hotter side was too hot to leave my fingers on for anything but a moment, the other side a skosh longer.
The brake pads on the drivers side had a tiny bit of play when the brakes were released, not that way on the passenger side. So, being concerned there might be a stuck caliper I went out to investigate today. To be fair I had never checked them before, at least that I can remember. So both rims had about the same amount of brake dust on them. I started probing around with a screw driver and couldn’t get anything to budge with it, no surprises there. So.. I grabbed my trusty pry bar, the one that got the jet pumps free the first time and started very gently applying force to the passenger side, back and forth, eventually I got to where it was sliding freely about, I dunno, maybe 3/8” of an inch or less. Did that several times just to make sure there were no snags in the travel. Went up to the tongue an pumped the brakes back up to re set the caliper, this is important so you do not push brake fluid out of the master cylinder reservoir. Then went to work on the drivers side, surprisingly this side was actually stiffer than the hot / passenger side. After I go it moving freely back and forth I pumped the brakes back up again. The next lake I go to will probably be 1.5 hours away on flatter ground so the temp check should be interesting.
I highly recommend that anyone who has brakes on their trailer use a pry bar like I did and exercise the brake calipers in their floating slots just to make sure that they are not trying to seize up on you.
That pry bar worked really well for removing the jet pumps the first time and for today’s caliper check. The curved ends allowed me to get between the caliper and the leaf springs and gently apply pressure on the caliper and then pull the caliper back using the more flat end. .
Here’s a few pics of the pry bar in action.. just be very gentle with the pry bar, move it around some to make sure you are not getting all the force off center. It took quite a few applications of pressure and then pulling it back-bottom pic- to get it to start moving back and forth.
Thanks for all the likes guys.. what a flippin journey this has been.
