There is good reason for bunks on a boat of this size and it is truly for weight. The weight of this boat is better supported by bunks rather than rollers. Rollers would add uneven pressure to one area of the hull over others, and that is the reason you will rarely see rollers used on anything of this size. Only for special occasions as noted above. As stated, you will be best served by bunks.
Same goes for disc brakes. Drums are used on almost all boat trailers, due to the conditions. Being dipped in water is the reason you will never find disc brakes on boat trailers. This is also the reason you don't usually see electronic brakes used instead of surge brakes. I was corrected on another forum, when a well respected member switched to electric brakes, and it turned out they worked quite well. But it is not going to be a recommendation for any longevity. So rest assured, surge/drum brakes will serve you well based on the amount of miles most of us have put on these trailers.
Good luck!
Got on the bunks vs rollers. Thank you.
Interesting on your take on discs. I have several friends with fairly good size boats (Grady Whites) and they all use disc brakes,
Also, I already have an RV with Electric over Hydraulic Disc Brakes. No power goes to the brakes, just brake fluid as in all other discs.
The all-weather power unit (electric powered) on boats does not get submerged.
I also discovered that EZ Loader uses EoH Discs on their trailers, and that Yamaha has disc brakes as the standard equipment on the trailer for the Limited S E:
Trailer
* Painted Trailer with Swing-away Tongue: Tandem Axle
* Galvanized Trailer with Swing-away Tongue: Optional Standard (Tandem Axle)
* Spare Tire and Mount: Standard
Disk Brakes: Standard
* Chrome Wheels & Aluminum Fender Step Plates: Standard
* Lights: LED brake lights
* Safety Chains: Standard
* Adjustable Winch Stand with Strap and Hook: Standard
* Height on Trailer: 10 ft. 11 in.
* Height on Trailer with Tower Folded: 10 ft.
* Length on Trailer: 25 ft.
* Length on Trailer with Tongue Folded: 23 ft. 9 in.
* Dry Weight on Trailer: 5210 lb.
Maybe that is a new development?
