Mainah
- Chapin, SC
- Limited S
I am designing my system for next year so when things go on sale I can buy them. I am going to have a 1180 lb bag in the center locker and a 400 lb bag under each rear seat. I have searched high and low for something faster than the standard impeller pumps. I am even willing to consider customizing an impeller pump as a primer for separate fill and empty centrifugal pumps. I also have plenty of 12v power and can add an inverter to go to 110v if needed. The only requirement is that I must be able to plumb lines to both the inlet and outlet of the pump.
So what is the fastest pump out there that you can plumb lines to under $600?
