- Raleigh, NC 27614
- 242X E-Series
@Bill D is right on! I've used all different types and "grades" of hole saws and never saw a difference. I've also NEVER had any chipping by doing the reverse approach as well....to the point that I no longer even bother taping (I know...sacrilege!)...but most of the items I've been installing all have a thick bezel on them anyway...so if there were a chip it gets covered up.
Also, it has been a while since I did this alarm, but I am 90% certain that there are no screws to attach it from the front....it has a screw on the main shaft on the back that holds it in place (which does mean you need to be able to access the back plate when installing it). I know this is true for the fume detector I just installed....
@KXCam22 A home depot alarm MIGHT work, but they are very sensitive to moisture....any water sloshing around in the bilge will set it off. Also they aren't designed for salt water and fail quickly (I know this as I used one under my fish tank salt water filtration unit in my last house and it died quickly in the salty environment). This alarm only goes off once the water reaches the height you install it at.....which I put in slightly higher than the bilge. So if the bilge can't keep up.....BUZZZZZZZZZZZ WARNING!!!!
