- Lake Ray Roberts, Texas
- Boatless
- NA
- Other
- NA
It isn't too complex @msavold . A single
bank charger will charge the batteries. If you have the ACR load side, just leave the battery switch on to charge them. You don't need to put the switch in combine. With the switch on, both batteries are on and from the load side, any appropriate charge on either will close the relay. On the battery side, the need to turn on the battery switch is eliminated. I currently still have my single pulse tech charger and it charges both banks as I also still have my ACR on the battery side of the switches. Hope this helps.
