Bow Filler
@Nathan_85 not sure what you mean. Are you wanting a spare? One cushion fills the entire open area in the bow.20150707_213517.jpg
@JetBoatPilot - do you make a bow filler cushion for the 2015 SX190? I know you have the vinyl since you make swim platform cushions to match.
@Nathan_85 as @RiverRat said, one cushion fills the bow. Are you looking for a second as a back rest? Not sure if the 190's are set up that way.
The 2015 190 should be the same as the earlier versions. I don't think the bow changed.
All 190 hulls are the same, they haven't had a redesign since being introduced in '12.
We just ordered one for a customers SX190 and the cushions are on back order from Yamaha until the beginning of September.
Thank you very much guys!
@Zeus2013 when you ordered the center bow cushion, did it come with the additional 'ledges' to screw into the fiberglass that the bow cushion would need to sit on? as seen on the factory bigger boats...
There aren't any extra parts for the 190/192 center cushions. The center cushion rests on the edges of the bow seat frames to all you need is to pull the bow cushions, drop the center cushion into place, and put the rest of the bow cushions back. Easy-peasy. The bow cushion fits very snugly so don't be alarmed by that if/when you get one.
@d_coyne1984 is right...
Hi everybody! I just got my 2016 AR190 and I would like to buy a bow filler cushion. While browsing on Yamaha Parts House website for AR192 cushion I’ve noticed that they have three different part numbers: for 2013 it’s F3E-U375F-00-00, 2014 - F3E-U375F-10-00 and for 2015, 2016 it’s F3E-U375F-20-00. Does anybody know what the difference is? 00-00 is least expensive followed by 10-00 and 20-00 tops it off. Any idea which one will be the best match? All cushions on 2016 AR190 have part # ending with 10-00: F3A-U35A1-10-00, F3A-U35A2-10-00, F3A-U35A3-10-00.
I just got one from Babbitts Yamaha. Called them, gave my info, told them what I wanted and they charged me $163.50 . I have no paperwork on it, but ill see if theres a number on the back. White vinyls white vinyl so it matched and fit. As far as I know the hull interior design has not changed on the 190/192 series.
That's a good price. There should be a part number in the back of the cushion.
OK, so your filler is for 2013 model -00 which is the least expensive. 2016 cushion # are ending with -10 so 2014 cushion F3E-U375F-10-00 should be a perfect fit, fingers crossed. Thanks!
We have a 2014, thats what was suggested and it fits and matches so were stoked.
So I got my Bow Filler cushion today, model # F3E-U375F-10-00. First of all it's gray, and second thing it drops down like an inch. I don't think this is correct. On the Boat Test Video for 2016 AR190 the filler is white and the whole bow are is level. What do you think guys?
It's not right. Mine is perfectly level and white.
