Scuba_ref
- Buckeye, AZ
My boat is stored under lock and key for the winter where even I don't have access to it. Given that, I've had a number of projects pile up over the winter. I got my boat back the beginning of April and have been busy working on it every chance I get.
The eight projects were:
1. Bimini Pole Quick Release install - Done, no pics
2. Swapped my 900 lumen drain plug light for an 8000 lumen drain plug light. This is the light I wired in to a missile launch switch so it can't be accidentally turned on http://boatpluglight.com/products/the-vega-prd-133-watts-at-8000-lumens
3. Swapped out my white plastic cup holders for stainless steel cup holders and added RGB LED rings.
4. Added RGB LED accent lights to the seating area and inside each storage compartment.
5. Added a high water alarm to the bilge area.
Alarm Sensor
Alarm Light and Sound Panel below helm
6. Added Fuel/Water filters to both engines.
Starboard Filter
Port Filter
7. Installed Perfect Pass.
8. Installed SeaDek.
Alarm Sensor
Starboard Filter
Port Filter
