Brandon_SC
- Belton, SC
- SX
I have decided to stick with conventional Yamalube for the oil in my SX230. It’s what has been used in it from its very beginning over 200hrs ago. I will also be using K&N oil filters for the ease of the welded nut on the end for ease of installation & removal. @grady dagenais You will want to make sure you warm up the engines and have them level on the trailer (or naturally in the water... that way you get an accurate oil level reading. You may already know this, but with these engines you can actually overfill them when they are cold... causing the oil to run into the air filters after getting hot.) just like @AZ Native said
*Edited to say Air and not oil filters
