Ron@Scarab
- Fort Myers, Florida
- Scarab
- HO Impulse
This Forum Post that I am going to take my time to write here is only to help people understand the system of the Carbon Ring, the support ring, and the protect hose. I am not going to waste my time here to get bashed for something that I didn't design, so please keep the snide comments to a minimum. As my Dad always told me,"Don't expect to come before me and complain about something unless you bring with you at least 3 solutions!"
So here goes:
First, the Carbon ring is a wear item, it doesn't last forever. Secondly, it needs to have lubrication "Water" while running it for cooling and sealing purposes. When your boat is in the water, the 3 components (Carbon ring, support ring, and the protect hose), when used together, will create a seal to keep water from entering the bilge.
Now, for those of you that don't know this, this system works very well. However, the system can be hurt, or Prematurely worn due to these few actions I will list below.
**Poor engine alignment///happens but rare
***Running your boat on flush for more than 90 seconds without manually lubricating the Carbon ring and support ring for cooling. In other words, you would have to run cool water over it if you plan on running your boat for more than that. (Which is unnecessary)!!! You are only flushing your exhaust manifold, not the motor! "You" are prematurely wearing out the Carbon ring against the support ring. The support ring will cut into the Carbon ring causing an uneven gap.
***Lack of service inspections by your dealer to help avoid this issue altogether***
###A Protect hose that has shrunk over time allowing a gap between the Carbon ring seal and the support ring allowing an excessive water leak. ### It is part of the service inspection at every service interval.
The last issue that I just listed is usually the culprit 7 out of 10 times. It can shrink from excessive heat!
I am saying this because I have replaced my share over the last 20 years (older styles and current) and have measured the old one against a new protect hose while the carbon ring/support ring are still intact and in good shape. The old protect hose will be weaker, and shorter in height.
Also, this design has been used since 2003 on every Seadoo 4-stroke watercraft and jetboat that Sea-Doo (BRP) made. It is currently used on all BRP PWC, Scarabs, and Chaparral's.
Lastly, to be clear here. BRP is only responsible for warranty on this, not SCARAB, which is handled all by your local dealer. I get it, it's a Scarab, they use BRP,...but please stop harassing Scarab here on this forum when it's BRP's issue that every one is talking about. Scarab is working with everyone, (The Dealers, BRP, and YOU to get a solution for you). You don't blame your SONY radio Failure on Scarab,..when it's Sony that failed and failed you (You go see Sony). One more point here to be made--I have noticed that a lot of people on this forum like to save a buck and are Do-it-yourselfer's. A lot of you can avoid a lot of these issues if you just get your boat serviced professionally by your local dealer, or someone who clearly knows about the BRP product with your boat.
I hope this helped everyone to get a better understanding and possibly avoid an unfortunate event while enjoying their Seadoo, Scarab or Chaparral Boat.
Kind Regards Always!
So here goes:
