adamsrotors
- Sacramento
you may have seen my issue post, after ripping off my rudder in some shallow water...
most of it has been fixed/repaired, yet I'm still experiencing some cavitation at higher RPM's that prohibits me from coming to full plane with a full boat.
this past sunday I was out with 6 people total and it was really struggling.
there is a high/loud hum or whine at 67-6800 PM and has a hard time getting out of the hole and up to speed.
I feather the throttle a bit and fight thru it, and it happens...eventually. we take off an all is well.
now days before, it acts fine...me and a buddy out only for testing purposes after the initial tear down, stick removal, and new cobra jet fangs & planning surface were add. almost unnoticeable really.
then yesterday after the issue with 6 people, me and 2 others (3 total this time) little issue but works fine, enough...really no struggle at all, only the sound for a quick few seconds, as it comes to plane.
clearly it's struggling with more weight on board.
...it's an impeller issue, right?
click HERE fo a video of the impeller after initially removing it to get the stick out.
does this look right? is there a uniform bend I'm not noticing that shouldn't be there or something?
