steveinmd
- 195S
Can you explain exactly where this wax goes? Are we talking about the clean out plugs? Do I add it when the plug is locked down in place? So no wax touches the plug outside diameter right? If it did I think the plug would not be able to be removed and reinstalled. Thanks
Goes on the plug seal. It's purpose is to fill any irregular spots/gaps on the rubber seal. You're not putting it on thick enough to permanently seal. With mine, it's just as easy to remove as before.
