bobsyeruncle
- Scarab
- 255 ID
Multi faceted post...a few issues at hand
255 open WE 2019.. 2x300
I am confused on a situation.. A month or so ago, out with some friends on the lake and everything was working perfect (45hrs on each engine). Backed into shore a little too close and sucked up some rocks and debris. It seemed to clear all up, but definitely some rocks went through. After that, all was well, boat working perfect still. Decided it was time to leave that end of the lake and head home. About 15 min. into cruising down the lake at about 5000rpm (perfectly smooth engines) something happened.. Port side (red rpm indicator) fell off like it was cavitating.. happened instantly. Engine shut down (safety?) due to high rpm? Fired back up and ran perfect (both sides)..until you hit 4500 rpm...then port side would fall off again (rpms falling behind sb side), other side stayed strong, but of course, couldn't go much higher as the port side would fall way off. I presumed we picked up something in the lake along the way...Limped back (4 hours) at 4000rpm smoothly with zero other issues.
Once the boat was out of the water, immediately spotted two rocks jammed on the exit side of the impellers on SB side...(realized later this isn't the side that was causing issues?)
The boat was due for 50hr service (notifications popped up on way back to launch) , so left the rocks in there for dealer to see and do full inspection on drives/impellers, etc when it went in for service. ( a few days later)
Got the boat back, and finally decided to get back out on the water yesterday... Fired up the boat, and immediately the service engines warnings came up. Boat just came back from service a month ago...warnings weren't cleared. Kind of frustrating as nearest dealer is 4hrs away..but, whatever, can deal with the warnings.
Got away from the dock, and hit 4500rpm....exact same problem. Port side cavitating/falling off (rpms falling way behind sb side)
Limped to the nearest beach and let the kids play for the day...
Got home and climbed underneath with the flashlight... Starboard side had a stick up in the intake side of impeller ..but unsure if that could really cause an issue or it would just be spit out immediately as we could have picked that up while loading the boat? Or...would it be stuck there causing issue? (Even though this side wasn't causing any problems) What I did notice was maybe a fair bit of damage to impellers? Maybe this isn't much? Hoping you guys can help shed some light... Could the rpm (perceived cavitation) issue not be related to the drives at all? What else could cause this happening mid cruise in the middle of the lake?
Here is a photo of the port side (no stick) and sb side with the stick... are these impellers damaged too much to work effectively? If so, shouldn't the dealer have caught this upon inspection?
Also a presumption...but the right and left buttons for starting should correspond to the side of the boat the engine is on? So much more going on here than my old 470 with a Hamilton..lol
Thanks all.
Thanks all.
