Clean out hatch levers
Final Update from me on this topic - I found a solution I am VERY HAPPY and am with final results
I purchased - Stainless Steel Latches 2.5" from Amazon, unsure of what to expect. Upon opening them, they are sturdy! Heavy duty, durable, stainless construction, I was amazed that they only cost $40! The description of the product is "YUSOVE Flush Mount Latch Fits 2-1/2" Hole,Non-Locking Surface-Mount Latch,316 Stainless Steel Boat Cam Latch"
Small Issue - The Pin needed to be driven in another 1/8 inch, I just tapped it in with a punch, I do not expect others to have that issue, but it was something I noticed, so I fixed it and went on to installPXL_20240623_182235828.jpg
Installation - These are plug and play, literally no adjustments, same as OEM, just needed to set the height of the cam to desired locking pressure PXL_20240623_210247461.MP.jpg
Photo of old -
Part Comparison -
Final Verdict - These are fully stainless, plug and play, better than OEM in every way, and cheaper.... MUST BUY UPGRADE!
Small Issue - The Pin needed to be driven in another 1/8 inch, I just tapped it in with a punch, I do not expect others to have that issue, but it was something I noticed, so I fixed it and went on to installView attachment 222342
Installation - These are plug and play, literally no adjustments, same as OEM, just needed to set the height of the cam to desired locking pressure View attachment 222346
Photo of old -
Part Comparison -
Wow this is a really great product write up. Do you think because they are stainless you can tighten them down a little more? In essence I am trying to ride my boat of any vibration rattle
Great question! - So I am slightly worried that the stainless T-handle might be able to tap inside the cup, but wont know until I sea trial it this week. To you original question about hatch pressure, you can absolutely tune these to provide the clamping pressure you need. I think you are smart to try to limit vibrations and rattle, every bit helps to make for an enjoyable day on the water.
They weren't kidding when they mention not for use in salt water. These things turn to powder
