If you have any water in your oil add 1 pint of Dextron 2 transmission fluid to the oil as it will work as a catalyst to mix the water with the oil and make it easy to remove all the water with an oil change.
Aright thank you everyone. I officially have both engines running.
Both air filters are wet with possibly some oil on it.
1.The oil on both engines look normal.
Just wondering wouldn’t the water settle on the bottom of oil compartment, or would the dipstick definitely show cloudy. Should I just drain a little oil to check?
2. Also, one engine has a little higher pitch than the other one which is deeper, does this mean anything?
Im only gong on what you say about the oil looking good right now. If it has any milk in it it needs to go right away before you run it to full warm up
If oil is in your air filters then you will need to buy new ones and if water went into your oil it will raise the oil level and get oil into your air cleaners so I would think you have water in the oil, MR1 engines have the crank case breather in front of the air filter element and if people overfilled the oil during oil changes this would put the excess oil into the filter and ruin it, so either you had too much oil in the engines in the first place or you sucked in water and that is the most likely situation so be careful running it overfilled or with water in it if that is the case.
This has been difficult to figure out since I thought you already had the plugs out and the engine was refusing to turn over with the plugs still out That was why I thought your pump or your starter were stuck
Thank you for your help. I apologize for the confusion. But the engines are now starting just waiting to get an attachment ( the one I just bought was wrong one) for the hose to run the engine on.
You’d think there’s water in the oil, but somehow the oil is cloudy.
Would you suggest emptying a little oil , before even trying to run it with the hose for a few minutes?
Do you have an oil extractor? You will need more than one oil change to get rid of all the cloudy oil/water mixture. More oil and less water is good. empty what you can and replace what you can.
