- Florida
- Other
- Other
The new Ultimate A k will also be mechanically compatible with the new mega fang plus system or the L T s that part is your decision , but the ultimate system will allow you to set the fins to go up mostly out of the water at speed if you are using the surf point this may be a good choice , and they are adjustable if you want to have them stay down for super steering at speed or at idle if you choose to keep them in the water at planning speeds plus this set is spring Loaded just in case you run over a rock wall or some fixed object and they are tempered aircraft aluminum so they can work at all speeds and not need to be huge so they still keep the V configuration and not in the way. Plus very important! You also get the second tie rod for your boats steering system to be balanced out, and with that tie rod you can set the nozzles and fin tow in settings knowing they will stay set. Water sports to docking these cover it all . the total Ultimate A K with the complete mega fang plus setup will be about $644 with free shipping in the U S A
