FSH 210 Sport
- Tranquility Base
- FSH Sport
I had meant to say Lee boards, which are similar but different than a daggerboard. Lee board design and why.
I bet another on the other side and more forward would take the crab walk out of the troll.
Was revisiting this thread and re read your post… I bet you are are correct about an additional board forward would really help to stabilize the crab in a rear quartering wind.
A bit of and update, I’ve been using this dagger board all summer, and after getting some better clamps the dagger board stays straight now. I can tell you that it becomes apparent very quickly if I start trolling and have forgotten to put the dagger board out. I use the dagger board with the trolling motor and or trolling with the mains. It will still skid a bit in stronger rear quartering winds. I bought a 30” drogue as an in between for my 18” and 50” (the 50” is a lot of drag!) drogues and that has helped to dial in the braking I need in a down wind scenario, which also helps with the amount of skid there is, as it keeps the trolling motor pulling strong enough to maintain good directional control. The other thing I have done is to switch over to Legacy auto pilot from Advanced auto pilot on the Rip Tide Ulterra trolling motor. The difference between the two is that Advanced lays down a gps track and Legacy is a compass bearing. In very windy conditions, the Advanced auto pilot will do everything it can to get back onto that gps track which means it will make very sharp turns-not conducive to keeping trolling lines from crossing and becoming a total cluster! The Legacy auto pilot is much more subtle albeit not as precise, but much much better for those very windy conditions.
