Mainah
- Chapin, SC
- Limited S
E/X series wiring and ecu I/O connections are materially different. That said I don't think the AR is that much different from the LS. Just tower, docking, and lights I think are far as electrical controls. I don't have a wiring diagram for an AR to confirm if the I/O was swapped on the gateway but that might just work to get an two more screen buttons that could be wired off the gateway.
I really do recommend buying tech manuals with the wiring diagrams if you are headed down this path.
Good luck
Good luck
