I changed mine out for black because the white ones get so dirty. I found them at the local hardware store. Amazon sells them in bulk (10 pack) They have options with drain holes and without. If you go black, you do not need the drain hole as it wont show the beer stains.
the verdict is in... I bought one just to verify, not that I didnt trust @Scuba_ref but I wanted to triple check.
I didnt pull the adhesive off the back, but from the photos you can see the difference it makes... Man it makes it look clean.. I started to clean up all the glue and adhesive off the old ones today while the fam was on the 4 person tube chilling...
