Descaling/cleaning
Speedling
Cedar Lake, IN
SS
Anyone got bright ideas on flushing engine to clean insides well?
I had some overheat warnings so i pulled my thermostat and while not bad i'd like to have a bit more peace of mind. About to let my thermostat soak in a diluted vinegar solution for a short time and then brass brush it. But all the internal parts?
I'm afraid of using something too corrosive and have heard that vinegar can damage aluminum.
I have half a container of salt away that I will be using asap for starters
Setup a small kiddie pool under the pumps. Get some marine descalling solution and a pump, fill the pool with descalling solution and recommended water then connect the pump to your flush ports and pump the solution while running the engines.
You need to check your thermostat in hot to make sure it opens fully, this test is usually illustrated in the service manual.
Here’s the thread @CrankyGypsy did on descaling his engine… but looking at the inside passage of your thermostat housing I don’t see much stuff in there. The minerals I see on your components looks it’s deposited in places where the water just sits and doesn’t flow. Since the other engine is giving you any overheats at this time I’d try a new thermostat and see if that solves your issue for at least the rest of the season. Perhaps there is some scale keeping the thermostat from opening fully but thermostats do fail over time
Descaling document;
Thanks guys! Good info here. At work now but I agree it's not like i have a lot of buildup. We bought boat from someone that did brackish and salt water so we did saltaway a few times a year originally and again a few times after bimini run 2018. Our first long run after purchasing was the starved rock to peoria and back. Wehad an overheat then. I believe it was the other side and i replaced the thermostat. Since i am into it i may replace both after cleaning them up.
I like the descaling idea after seeing some of the carnage others have had. My anodes on pumps and engine were checked before this year's bimini run and all looked good. So good in fact that i didn't replace one of them on motor and have a spare.
So after doing all this I may pull the pump screen even though all 4 pee holes were clearly flowing proper volumes.
The exhaust may get taken apart a bit as well just to see if anything obvious is going on and if so i dig deeper.
Meanwhile my wife is like,uh, we should go to Shelbyville this weekend! And don't forget the gary air show is coming up!" And "we haven't done a run up into Michigan yet this year!
And lastly i will look at the sensors that may be cuprits.
Right on…. Just looked again at the picture you posted and there is like no scale build up in the passage….
Interestingly the one in there is a 50 degree celsius one. Not 60 as linked by others before me
Thermostat bench tested perfectly at the 50 celsius.
Reinstalled and ran salt away on both motors. My wife, my youngest(he's my mechanically inclined one and usually helps me) and myself all agree they both sound rough.
Like rough idle.
Did a batch of salt away using the dispenser on both engines so like 3 minutes or so run time on the hose.
I am curious on the spark plugs.
I learned that ngk has some plugs not from the ngk factory anymore and they put the ngk labelon it. I have come across plugs for work that were broken for the first time.
I also did iridiums this spring knowing they would hold up to salt water better.
Hope to swap the motor that overheated and run another salt away batch through.
Side note my hose has a repair end and it sucks. Different hose tomorrow.
Second side note: time to take pumps apart and regresse/inspect. I think some of what we hear could be pumps rattling a bit. It's been a few years since i pulled that nose cone and greased.
All the good things that should be done anyways i guess.
Maybe a little overheat scare is what i need to get it back to beautiful mechanically just like we did to the interior and exterior
From a thread I did on NGK plugs a short time back…
Next I asked her (NGK csr) about the plugs having the translucent or cardboard protectors. She told me that the plugs with the plastic covers are made in the USA, and the ones with the cardboard are made in Thailand or one of the other countries that makes them.
I appreciate that thread for sure! My boxes were plain white, no description or writing at all. I have one more 4 pack and am getting into that tomorrow.
This is what i have. I am going to check my amazon purchase and see if labeled NGK and leave reviews appropriately.
Heat warnings today and 102 heat index so may wait till near dark to start if I do anything.
Convenient black plastic wrapper they had around the box though.
Those look like Chinese knock off NGK plugs. NGK plugs come properly packaged with the company logos.
this here is a certified seller for NGK spark plug, I think I put that in the thread that I did on them. Your engine probably uses a different plug than mine, but this distributor is certified, the plugs come in NGK labeled packaging.
Just updating on this "issue": i opened the hatch while wife drove and saw water coming out the back of thermostat as soon as we were almost on plane. Once shut down, i took a look (stuff gets hot!) And removed the big hose going to thermostat and adjusted. It looked as if i had perhaps put on too far and was kinda flared out. Adjusted that and seemed to no longer be spraying water so that's comforting.
New plugs helped even out motor noise a bit. The iridiums being knockoffs may have been a culprit. At first fire up and at idle that motor still (to me) sounds a little rougher than the other but as i have bought the boat like 10 years ago or something and do big water exploring (Lake Michigan, Bahamas, Lake Cumberland, lake shelbyville) we have put a LOT of hours. Purchased with 240. Probably due for intermediate bearings and valve job or something.
I don’t know which plugs your boat calls for, but if it’s usually best to run the plugs that are called for.
If you suspect intermediate bearings, take a long screw driver or wood dowel etc and put it on the bearing housing while the engine is running and put the other end to your ear, this is a sort of stethoscope. If the bearing is going bad you’ll know it, lots of random sounds, not rhythmic … compare the two against each other.
Have the valves been adjusted? That’ll make the motor run rough if they’re out of spec. On my boat it calls for a valve lash check every 200 hours.
You bought the boat with 240 hours, how many does it have now? Love that you’re putting on the hours and enjoying the boat!
Good deal on stopping the leak… a new hose might be in order as well?
No
No idea on hours. No meter on 2009 and older. Gotta buy the software and wiring to hook to a laptop. Or bring to a dealer i guess
My buddy that is a mechanic and bigger gear head than me suggested I look at the fuel injectors and fuel filter
Looks like the only filter is on the in tank pump. I am thinking of running boat down in fuel before I open the tank up but I may look at just replacing all fuel injectors since the boat IS like 17 years old and I know some people have had issues before.
A clogged injector makes a bit of sense as to why it would act up occassionally. There is I assume a mesh filter on top of the injectors and if that gets a bit of junk could allow it to run, but possibly lean, causing a rough idle as well which is what we experience mostly now.
Yay for more ideas!
