AZMark
- Phoenix, AZ
- Limited S
Mine was the exact same way. Starboard cable the oil would go through and port side i has the psi cranked up to 90 ish and let it sit overnight and nothing moved.
I have tried everything, switched to a very thin penetrating oil, tried putting it under vaccuum for a while to see if I could suck anything that was stuck in there out, switching where I had it clamped, moving the cable all over. No oil movement at all.
When I get the new one and swap it out I’ll try to cut the cable open to see what the hell is blocking it in there. My steering is tight but I can still move the wheel with one hand so I can’t understand how there isn’t a little room for oil to get through next to a moving cable.
