Bennie
- Loxley, AL
- Limited S
I'd like to install this on my '15 242LS -- would you recommend a separate feed or use the feed from the tweeters to assist in equalization?None that I've heard....it isn't handling the low frequencies...as the sub has that covered, if it was I'd expect it to struggle with low end distortion, but high end...is its sweet spot.
(I don't have a sub or an amp)
