McMark
- Monongahela, PA
Finally getting some warranty cracks fixed. Here's the list so that other 2015 AR240 owners can check their boats in these areas.
Warranty work.
Port side. Bulkhead needs cut back. Putting too much pressure against outer hull. Vertical Spider cracks in the side of hull at the bulkhead.
Port side rear seat in the radius between the seat cushion and inner liner. Glass guy said this was probably there when they built the boat.
Small blister in lifting strake with spider crack. Void found in hull.
Void found in pass through area below the tow point and next to the right side of the hydro turf. About quarter sized.
Dash cracks at every screw hole where the instrument panel screws to the glass console.
Both rear tie downs need pulled and resealed. The glass guy said it looks like there is no sealant at all on them.
Non warranty work.
Someone scratched the port side rear decal while in storage. We're cutting the section of the decal out with the scratch, fixing gel if needed, then reshape the rest of the decal. I want them gone but the Mrs likes them. Arggghhh.
The glass guy asked me how I liked the Yamaha. I told him I loved how it runs but in my opinion, it's a soft boat. He agreed.
Work to be finished in 2 weeks. I'll keep you posted.
Warranty work.
Non warranty work.
