McMark
- Monongahela, PA
Trust but verify is a good motto. lol
Very smart!Just in case anyone is interested, the original owner of my boat reinforced these when he moved to the keys and used to store the boat up on davits. Here is a picture of the reinforcing plate.
@McMark I'm just baffled with how Yamaha does certain things, it's hard to believe!Trust but verify is a good motto. lol
Florida snob!
So, what would be the best tow point for large tubes? SAA?I wouldn't consider those for tow hooks. Too close to the waterline. I'd want the tow rope to be inclined somewhat from the boat in distress to the tow boat. If I had to, I'd make a yoke between the back 2 cleats then to the bow eye of the boat in distress. And take it real easy.
Although these u bolts are technically called tow hooks, they are nothing more than transom tie downs for trailering.
Finally getting some warranty cracks fixed. Here's the list so that other 2015 AR240 owners can check their boats in these areas.
Warranty work.
Port side. Bulkhead needs cut back. Putting too much pressure against outer hull. Vertical Spider cracks in the side of hull at the bulkhead.
Port side rear seat in the radius between the seat cushion and inner liner. Glass guy said this was probably there when they built the boat.
Small blister in lifting strake with spider crack. Void found in hull.
Void found in pass through area below the tow point and next to the right side of the hydro turf. About quarter sized.
Dash cracks at every screw hole where the instrument panel screws to the glass console.
Both rear tie downs need pulled and resealed. The glass guy said it looks like there is no sealant at all on them.
Non warranty work.
Someone scratched the port side rear decal while in storage. We're cutting the section of the decal out with the scratch, fixing gel if needed, then reshape the rest of the decal. I want them gone but the Mrs likes them. Arggghhh.
The glass guy asked me how I liked the Yamaha. I told him I loved how it runs but in my opinion, it's a soft boat. He agreed.
Work to be finished in 2 weeks. I'll keep you posted.
