Mainah
- Chapin, SC
- Limited S
That would help but is the area flat? Attching a flat ring beind there may crack the gel coat if not flat. The more mass the panel has the less likely it will oscillate because of the speaker. I don't have acces to my boat and I don't recall how stiff that area is. Given the location of the rub rail right behind the speaker I think this is a pretty strong spot in the outer hull so I am not too worried about that.
The proximity of the the speaker to the upper bend in the panel also makes for a pretty solid spot. All of that said if you were to super slow mo video that speaker you would see just how much deflection it will cause in that panel and depending on how thst panel is mounted JLs cranked up on a bass guitar riff may cause some undesired vibrations.
